- 7 สิงหาคม 2022
- 31
What is the best job to make clear and fine enough line generation under night version? It is making the best job for user to use Berlinlasers 980nm infrared laser line generator. It emits invisible infrared laser beam from 980nm IR laser diode within 100mW to 500mW. The special use of metal heat sink cooling system and APC, ACC driving circuit board are configured with 16mm and 26mm diameter metal housing tube. This IR laser enables convenient installation and easy IR line projection onto any raw material surface.
The advanced use of glass coated lens within 10 to 110 degree assures high linear quality and high fineness IR line generation. This 980nm infrared laser line generator projects various line lengths and line finenesses. It is operating well with night version device, and makes efficient conversion into a highly fine and clear infrared line in distance. When it makes freely adjusted infrared line fineness and IR line projecting direction, this 980nm infrared laser module makes high precision and high stability IR line generation in long lasting use.
Technical data:
Item: Berlinlasers 980nm 100mW to 500mW infrared laser line generators
Laser class: IIIb, IV
Optic lens: 10 to 110 degree glass coated lens
Adjustable focus: yes
Applications: military targeting, laser medical therapy, intelligence system, surveillance, infrared laser communication etc
Technical data:
